Gjac
Jul 08, 2020Explorer III
One possible con not mentioned is if you forget to put the locking pin in after you fold it can fall and drag on the road if no tow car is attached. This happened to me once when I went to get gas for the MH, thankfully a passing car told me that sparks were coming off the tow bar. I now use a bungee cord to keep the two legs from extending when no car is hooked up as well as the locking pin. Another minor problem is if left on for several years the lock going through the pin can rust and penetrating oil is need to open the lock.
38,780 PostsLatest Activity: Aug 05, 2026
