RRodda's avatar
RRodda
led bulb source
I wish to replace the 12v halogen bulbs with led. The halogen bulbs are the tiny g-4 bulbs and are set into a concave reflector in the ceiling above the couch. What is a place to find small enough led bulbs to fit?
  • I have been using these:
    M4 Elite
    After going though several different types I found these to be the best for my fixtures. The LED's used are much brighter than the cheap Ebay ones but are a bit thicker. The larger ones will not fit in mine but may in yours...all depends. Also many bulbs have pins that are a hair to thick to easily fit the sockets....again all depends.
    I found that finding one that looks good on paper than just buying one or two to check them out worked best, You may also find that removing the puck light from the ceiling may be the easiest way to get the new bulb into the socket.
  • jwally9844 wrote:
    I have had good luck with m4products for LED lights.
    X2
