tpi
Aug 02, 2014Explorer
ron.dittmer wrote:
I just went through an interior "Bulb Conversion" from standard incandescent to LED on my car. If your motor home uses the same bulbs as my car, then you could benefit from my experience. For my trunk bulb, I was able to find an LED replacement that was a whole lot brighter. CLICK HERE to see my write-up.
My motor home has florescent light bulbs throughout. I had looked into LED replacement bulbs for them, but I lost interest because of cost and wiring changes.
Thats my feeling on the fluorescent also. As long as the fixtures work properly there is not much point in changing them. The F15T8 lamps are far more efficient than incandescents. I did switch out the lamps to tri phosphor lamps which have more pleasing color rendering than the standard thin lite lamps.
I highly recommend RV LEDs though when replacing incandescent. I've used garden variety LEDs from ledtrailerlights.com and all have performed reliably and at brightness near or beyond the incandescents. Those high lumen Samsung lamps look interesting, but all of mine are working properly.
