WA7NDD
Sep 01, 2014Explorer
I replaced all eleven yellow, dim incandescent lights in the MH with $8 each LED. I did not select warm, I bought the brightest LED I could find and they are great. Those that say there is little difference, did not do the research. There is a huge difference, you get a bright white light.
I liked the LED's so much that I went to Home Depot and changed my home outside 40 watt incandescent lights to 60 watt LED's on sale for $6.97, now back to $10. I had a total of 480 watts of lights turned on by the security light detector. I even replaced the security flood lamps with LED flood lamps, $27. Now the security detector turns on all the same lights only at 100 Watts of power, and just as bright as they were before.
