I am in the process of mounting a modern TV in our 05 Bounder. Most of the non articulating wall mounts just hang the TV on a bracket. What do you use to keep the TV from bouncing off the bracket? My...
I mounted a 50" LED TV in front using a plywood box mount.
After seeing some other conversions, I mounted the rear TV over a hidden compartment using 3 Euro Hinges that allows flush mounting and no visible hinges or locks.
