dougrainer
May 02, 2019Nomad
RobertLang wrote:dougrainer wrote:enblethen wrote:
Look in chassis owner's manual for fuse locations. . . for trailer left turn fuse.
Not correct. RV OEM's do NOT wire . . . You still have the TOW plug wiring fuses for the LR and RR. Doug
According to the FORD F-450 manual, there is no listed fuse for left rear only or right rear only fuse. But I will look into the JAYCO fuse panel. Easier to replace a fuse IF I CAN FIND ONE THAT IS BLOWN.
Otherwise, I am running a new wire.
THANK YOU!!!
Jayco does NOT run their own fuse panel for chassis systems. NO OEM does. The Lighting is connected BY Jayco to the chassis harness. Over 20 years ago, the Chassis makers separated the TOW harness wiring from the BOX lighting harness. They did this to prevent having a short in the Tow system causing loss of lights on the BOX system. It can be difficult to find the correct fuse. I NEVER consult the owners manual fuse box schematic. It is quicker for me to take my 12 volt test light and check every fuse in BOTH chassis fuse blocks. The one inside by the E brake and the one outside in the engine compartment area. Doug
Related Content
- Feb 01, 2026Community Alumni
