dicnic
Apr 11, 2011Explorer
Welcome Tom, as others have stated, it is wonderful to have a real expert on board. You stated in another post.......
"One more thing. When changing from a DEXRON-IIIH product, always drain and fill twice to ensure maximum TranSynd content. Flushing machines are not typically recommended and usually give the same results as a double drain and fill (per a test we ran at Allison)."
How is the "double drain" process work? Fill with Transynd, run the coach for awhile (?) then drain and refill with NEW Transynd or re-use what was drained or ???
I realize this might be obvious to those who have accomplished the process but I would appreciate more details on the actual process.
Thanks and again, welcome!
38,782 PostsLatest Activity: Sep 10, 2026
