J_Walker
Apr 12, 2011Explorer
hzjcm8 wrote:
Dicnic,
A double drain and refill goes like this. Drain the current fluid, toss it (dont' reuse it) and refill with TranSynd. Drive the RV around until it's warmed up and shifted through the gears. Then, drain it again and toss it (don't reuse it). Change the filters and refill with TranSYnd. At this point, you're good to go. Run it until oil analysis says it's time to change.
Hope this helps !!!
An alternative to this to convert from Dexron to Transynd is to drain and fill with Transynd, run two years, and drain and fill with Transynd again. This is what I did and is a little more cost effective and what I believe is the best way to convert, but not the quickest.
38,782 PostsLatest Activity: Sep 10, 2026
