hzjcm8
Apr 13, 2011Explorer
darrelorn wrote:
I have a 1000 series six speed Allison in a 2011 Workhorse chassis. When hot, fluid is a little above the cold mark. How many quarts/liters needed to bring into hot range? Who should have filled this transmission properly, Allison or Workhorse. Thanks.
Allison only fills to final test the transmission before it's shipped. Once it gets to the vehicle builder, then the engine is connected the hoses are installed and the whole system is topped off. If's it's low then it's the RV builders fault.
PS: I'm "guessing" you're a quart of two low. But, add a quart and check the dipstick.
38,782 PostsLatest Activity: Sep 10, 2026
