hzjcm8
Apr 20, 2011Explorer
supercub wrote:
I just purchased an 05 Fleetwood Revolution LE Cat 400hp and Allison Transmission. It only has 9200 miles on it. I have no idea what has been done to it as far as mainteance. Any recommendations on what kind of servicing I should have done? Thanks
Brian
Supercub,
Is your name from flying a supercub? I have a pilots license but only fly the Microsoft Flight Simulator now .... too old; don't trust myself with ATC. I could still handle flying but the ATC rules might get to me.
Since you don't have history on the fluid, I'd recommend a fluid analysis to determine the condition and let me see the results. I'll give you my recommendation based on the results. Or, you can just do a refill with TranSynd, drive it around for 30 minutes, drain again install new "high capacity" filters and then refill again with TranSynd. Then you're good until the next filter change.
38,782 PostsLatest Activity: Sep 10, 2026
