Jarlaxle
Apr 22, 2011Explorer II
hzjcm8 wrote:Jarlaxle wrote:hzjcm8 wrote:
Hi all,
I've just joined Good Sam Club. I was the former Transmission Fluids Engineer at Allison Transmission. I held that position from 1990 until my retirement in 2009. Let me know if you have questions about TranSynd, the TES-295 specification or just anything to do with automatic transmission fluids. I'm here to help.
My Genesis has an MT643 trans behind a DT466 engine...Dexron III, right?
Nope !!! I no longer recommend anyone use DEXRON-III. Use TranSynd or another TES-295 for the best possible performance and durability. DEXRON-III is an obsolete spec so anything these days is being manufactured under the label D3/M meaning DEXRON-III/MERCON. These fluids are manufactured and sold but have no license and are no longer approved by either GM or Ford. I used to sit on the GM DEXRON-III committee and I can tell you that these fluids are no longer evaluated by anyone at GM. So, it's sort of like "buyer beware" when it comes to any DEXRON-III (D3M) products on today's market. Also, do not use DEXRON-VI due to possible seal issues with your older MT transmission.
PS: D3M fluids (DEXRON-III) tend to lose viscosity so cooling won't be as good due to lower cooling circuit flow. Unless you change it every 25,000 miles. So, just put in TranSYnd adn you should be good for at least 100,000 miles. Don't forget to change the filters too.
It's wound up 307,000 miles (filters changed annually, roughly 25K) on D3...honestly, I'm leery of switching it at this point! Is TranSynd compatible with D3? Flushing all of the old fluid out at this point is just not feasible short of component replacement. (This thing has the biggest trans cooler I have ever seen!)
Also, what (if anything) can you tell me about the oddball AT500?
38,782 PostsLatest Activity: Sep 10, 2026
