DannyLeininger
Apr 23, 2011Explorer
Tom, having you here is amazing! Thank you. I have read all the posts so far....wow!
I recently purchased an 07 Mountain Aire 45' with an Allison 4000 with Transynd. It had been repo'd so I'm missing most documentation and have no maintenance history.
I assume the 4000 requires the first primary filter change at 5K like my last 3000 did???
You have stated a 4000 could go 100K+ miles between fluid changes provided proper filter changes and oil analysis. But, not knowing if filter changes have been done, what steps would you recommend I take? Should I go ahead and change the fluid and filters so I have a good starting point? Or just change filters?
Can you take the original Transynd to 100K+ miles? Or is this done after the first complete change?
38,782 PostsLatest Activity: Sep 10, 2026
