wny_pat1
Nov 23, 2011Explorer II
NRALIFR wrote:
Tom-
While researching the correct fluid to use in a ZF manual transmission, I found this in a document on ZF's website:
"ALL S5-47 DIESEL SPEC. TRANSMISSIONS USE SYNTHETIC MERCON® (FORD P.N. E6AZ-19582-B or CASTROL TRANSMAX-S (TRANSYND)".
This seems to be indicating that Transynd is the same product as Castrol Transmax-S. Can you confirm that?
The reason I'm asking is because neither Transmax-S nor Synthetic Mercon are available any longer.
Thanks.
http://www.fcsdchemicalsandlubricants.com/Main/quickref/mantrans.pdf
38,782 PostsLatest Activity: Sep 10, 2026
