hzjcm8
Dec 04, 2011Explorer
MandalayJim wrote:
Tom Johnson,
I am interested in the fluid analysis that your company can do for me. However I need a little more information. I am at 41k and 43 months on my 2008 motorhome with factory installed Trans Syn and gold filters. I beleive that my first fluid change will be timewise at 48 months.
If through analysis the fluid tests good and I skip that fluid change will Allison accept that report and perform warranty work in the case of transmission failure in the future?
Thanks for all your answers on this form!
MandalayJim,
I cannot speak for Allison anymore but the oil change recommendations say that oil analysis is the "primary" way to determine drain intervals. So, I believe you are safe to skip the oil change if the analysis is good. I do recommend you change the filters according to schedule. I would also recommend you install the new "High Capacity" filters to push the filter change out to 75,000 mile intervals.
38,782 PostsLatest Activity: Sep 10, 2026
