- JimGoExplorerHow can you tell if you have Dexron or Transyd? Did Allison stop using Dexron in a certain year?
- rvrepairnutExplorerGuy kept filling his trans It would have mighty overfilled if it was a ps or leveller leak plus AW32 is clear oil not redish like trans oil
- ChaosAgentExplorer
Jim@HiTek wrote:
ChaosAgent wrote:
Jim@HiTek wrote:
Thanks for your advice and help here on the forum, hzjcm8.
I had my Allison 4 speed back flushed and filled with Transyd at 136,000 miles back in '07 at a bus repair shop that was just getting into RV's. They used a big fancy machine and told me they flushed it until the fluid was the right color, 3-4 times if I remember. At that time they told me there was no need to replace the tranni filters as the back flush would clean them like new.
Is that true?
At 142K miles, I developed a hydraulic leak in the boondocks of Canada. I had a couple quarts of Transyd that I used up along with a couple pints of ATF stop leak I bought as I limped several hundred miles to Prince George. Also added regular ATF as needed along the way (small stores don't usually carry transyd).
Had a leaking hose replaced and the tranni topped off with more transyd. The mechanic told me it was OK to mix the standard ATF, Stop Leak, and the Transyd but I would like to hear that from you.
Should I have it re-flushed, or is it OK with those other fluids in there?
Thanks!
Just a question. Was this a 'hydraulic' leak or a transmission leak. In most cases, there's a difference.
Hmm. I'm not a mechanic but it was tranni fluid leaking from a hose near the back & under the engine (but not FROM the engine). Three or four feet from the tranni. I think the hose was attached to the rad cooler. I let the mechanic take care of it and he had a devil of a time getting the bad hose out of there because of frozen connections. The only fluid I was loosing on the trip was tranni fluid...which I kept topping off.
It was at the beginning a slow drip I could see under the rear of the RV, just a small 2-3" diameter puddle after each time we stopped (every 4 hours or so).
Sorry. The reason I was asking is that my rig has 3 different hydraulic systems besides the transmission, two of them back in the engine area.
I have the hydraulic system for the power steering and ISC 350's radiator fan. It uses AW32 clear hydraulic fluid.
I also have the hydraulic resevoir for the PowerGear levelers. It uses ATF.
And up in front I have the resevoir for the hydraulic system that extends and retracts the Onan Generator.
Had a friend that saw leaking hydraulic fluid and was almost sold a tranny rebuild before he figured out it was his levelers. - UltratravlerExplorerThat is what the label on the pail says, and that is what is advertised. Sometimes you just have to have a little faith. I have never had a problem with ebay, but there is always a first time. Good luck.
- ArchHoaglandExplorer
wineberrywinger wrote:
If anyone is interested in some TranSynd, I just bought a 5 gal. pail for $160, delivered, on ebay. The asking price was $179 or make an offer. He had 10 five gallon pails.
How do you know it's TranSynd in the bucket? I'm real leary of Eby stuff. - UltratravlerExplorerIf anyone is interested in some TranSynd, I just bought a 5 gal. pail for $160, delivered, on ebay. The asking price was $179 or make an offer. He had 10 five gallon pails.
- JimExplorer
Is that true?
Thanks!
It was at the beginning a slow drip I could see under the rear of the RV, just a small 2-3" diameter puddle after each time we stopped (every 4 hours or so). - ChaosAgentExplorer
Is that true?
Thanks!
Just a question. Was this a 'hydraulic' leak or a transmission leak. In most cases, there's a difference. - JimExplorerThanks for your advice and help here on the forum, hzjcm8.
Is that true?
Thanks! - wagonmaster2ExplorerTom,
Is it important to distinguish between a transmission fluid brand being Allison Approved TES 295 Lubricant and a brand listed as meeting Allison transmission TES 295, TES 398, C-4 and C-3 specification requirements? The latter brand will be much easier to obtain locally and somewhat cheaper.
Wagonmaster2
38,766 PostsLatest Activity: Jan 10, 2026
