goufgators's avatar
goufgators
Leveling jacks...
When checking the leveling jacks fluid level, should the jacks be in the stored position or down position? I believe I know the answer (stored) but not sure. / Thanks! / Larry
    Thanks for the replys! / Larry
  • Do not over fill or you'll have a little bit of a mess when you retract the jacks the first time. Excess fluid will be vented out.
  • Should be fully retracted (stored position). This way you can see the actual fluid level in the reservoir.
