rthrash777's avatar
rthrash777
Leveling jacks and backup camera not working
1997 Holiday Rambler Endeavor
Started having issues with the leveling jacks not coming on some time ago. The problem was intermittent, but kept getting worse. When this happens, power is not being supplied to the control box at all. Later started having trouble with the backup camera not coming on. Sometimes they would come on after driving for several hours. Replaced all 7 Ford relays behind the instrument cluster, replaced ignition switch. I fear the problem could be the "ACC" relay inside the box above the generator, but I am not sure. This relay is hard wired into the circuit board. Prior owner direct wired radio and CB to the house battery. Could this be a clue to a previous problem with the accessory circuit. What else could it be?
  • I'm thinking the accessory circuit is probably out. No panel lights in accessory position. I found what appears to be the original leads for the radio and there is no voltage with the ignition on.
