- If they are hydraulic jacks wipe them down with ATF (automatic transmission fluid) or hydraulic jack fluid. This lubricates the seals on the jacks.
- lryrob9301ExplorerWD40, run the jacks all the way extended, then spray on WD40, then retract the jacks. May have to do this a couple of times.
If you have one that is particularly sticky you can get a scissor jack and put under it to raise it.
38,766 PostsLatest Activity: Jan 10, 2026
