I get a notice, with a beep, saying my leveling jacks are not up. They are so I pulled the fuse to not hear the annoying noise. Any suggestions or do I need to get a Tech out here to look at it?
Filling it up may not take care of the problem. Most jacks go up by the springs If they don't retract all the was the buzzer will go off. You can clean all the springs and pistons with carb cleaner. I had to do that about 3 times now over the years. Make sure your jacks are all the way up before adding fluid.
To give better information and possible solution, we really need to know the brand of your jacks and if they are electric or hydraulic. The above info is excellent if they are hydraulic, first place to check is the fluid level. If electric, there should be a jack position switch that senses the position of the jack(s). It could need to be adjusted.
