Wijames
11 years agoExplorer
leveling jacks
I don't see leveling jacks on any of the Class C's around here. Do many of you use them and if so do you carry portables of attach them to the frame?
Thanks
Thanks
Desert Captain wrote:
On the larger C's, 29-32' I can see where a lot of folks feel the need for levelers. On the smaller C's 19 - 25', not so much. On our 24 footer it is just too easy to simply place one or two Leggo blocks under one side or the other. Yes you need to block both the duals when lifting one side and I have never needed to go more than more than two blocks high. Simply pushing a button is easy but often you need to get down on your hands and knees to make sure they are properly/securely set anyway.
