et2
Sep 22, 2013Explorer
Leveling MH
When additional help is need to get the MH  level ( so wheels aren't off the ground by using hydraulic jacks), would it be advisable to support both rear wheels? If you used blocks under one wheel the...
et2 wrote:
When additional help is need to get the MH level ( so wheels aren't off the ground by using hydraulic jacks), would it be advisable to support both rear wheels? If you used blocks under one wheel the other would be along for the ride. I assume the answer is to put support under both.
What is the most height you've had to drive up on? I've a couple heavy duty plastic ramps I used for my fiver that are about 2.0" at the high side. I only had one time with the last fiver which had hydraulic jacks that the fiver wheels were off the ground by about 1/2". I would need to try to get another ramp if this is the case.
