TwistedGray
Dec 14, 2020Explorer
MDKMDK wrote:
The 5.4L V8 is a great engine, and in a smaller coach would probably be sufficent. The GVWR on that model was 10,050lbs, so you'll likely be closer in loaded weight to the average GVWR of some of the larger class B vans out there. You could inquire from the rental company if they would be willing to give you a drive train warranty on it for 90 days, or more. Their response might be a clue?
You could also check with Ford and see what a refurbed engine and transmission replacement would cost, all in, if that's your main worry. Maybe it's less than you think, and that way, you could move forward knowing what to expect financially, if the engine or transmission were to fail somewhere down the road.
Cruise America gives the buyer a 3 month / 3000mi warranty. They have replaced the ignition switch and resolved an o2 sensor on mine without any issue.
