viajanteExplorer IIJun 22, 2021Light on Gas water heater switchThe light on the switch for the gas water heater stopped lighting up. I checked and the gas water heater is operating normally. Any ideas about what the problem is and how to fix it ? Thanks in advanc...Show More
CA_TravelerExplorer IIIJun 22, 2021If you have 12V on the ground wire from the switch then bad ground. Otherwise replace the switch.
Related ContentSuburban SW12DEL Water Heater On/OFF switch melts???Switching toiletsTowing lights issueAutimatic Transfer Switch?Replacement Lights for TT
