wa8yxm
Apr 06, 2019Explorer III
Ok the Power Gear system I have is.. I think the same as what you have (Power gear sold out to LCI)
The system consists of 4.4 modules
1: the panel inside the RV with the buttons. most of the electronics is here as well
2: THe level sensor. Take a piece of string and tie it to the right front jack. then run it under the RV to the left rear jack. Do the same with the left front and right rear (With a 2nd piece of string or just loope it around the rear and bring it back to the other side front
X marks the spot. Look above the X.. in my case it is in a basement compartment almost exactly above where those strings will cross.. ON the "Ceiling" of the compartment and next to impossible to get to.
Module 3 is the pump/valve assembly
Modules 4 are the jacks. (4.1.2.3.4)
38,766 PostsLatest Activity: Jan 10, 2026
