- RacklefratzExplorer II
Suburban52 wrote:
Does anyone know what this button does?
Yeah - question's been answered now. But use an infra-red temperature measurement device, and point it at that sensor, and you can confirm if your thermostat is working correctly or not. Temp readings should be close to the same between the two. - rlw999ExplorerIt looks like it's a Coleman Mach 8330-5191 Room Sensor
- traviscExplorerPassenger seat eject
- Suburban52ExplorerThanks, now I know.
- Thunder_MountaiExplorer II
rk911 wrote:
Ranger Smith wrote:
+1
It is a sensor for the thermostat
Yep... What they said. - 2bzy2cExplorer IIStop it!!! Every time you press that button, my garage door opens. Very annoying.
- dodge_guyExplorer IIIt’s for the government to listen in your conversations! Best bet is to caulk it shut!
Or it could be the sensor for the heat/AC?! - rk911Explorer II
Ranger Smith wrote:
+1
It is a sensor for the thermostat - BurbManExplorer IIIThat's the call button for the maid.
- Ranger_SmithExplorerIt is a sensor for the thermostat
38,783 PostsLatest Activity: Sep 22, 2026
