onrecess's avatar
onrecess
Live with no dash ac?
I have a gasser. It is not very cool driving with both AC units on, unless the dash air is on. I am looking at a Diesel Pusher (Dutch Star) and the dash air doesn't cool. I have heard this is common. I live in S. FL, and travel to Texas quite often. It is HOT. Will the driver's area be as uncomfortable as the gasser with no dash AC, or is the AC big enough to keep my cool?
  • carringb wrote:
    Why would you drive without the dash A/C on?
    When your dash A/C isn't working as is the case here...
  • Why would you drive without the dash A/C on?
    That's like saying your showers are cold when you have the water heater turned off...
    And FWIW - the capacity of the factory dash A/C is many times greater than your house A/Cs.
  • Yes. If you don't have a dash AC then one of these will cool you. If you only have two roof top AC then you need 4 to do the good. Three will be close but not what you want.
    https://densoheavyduty.com/rv
