GKAbbott
Dec 23, 2019Explorer
Powertour wrote:
Anyone installed a sound system in their rig & if so how'd you tackle that project?
Every trailer I've owned came with some sort of sound system for the living area.... they may have not been good, but there was something to work with (or outright replace). Not this Class-C, other than the in-dash radio with 2 WEAK speakers in the front doors there's nothing to pony off.
If you want to continue to use the in dash unit, install a DPST switch to switch the ignition sense wire(probably red) along with the B+ wire(probably yellow) between the house battery and the chassis battery. This will require running wiring from the house battery to the switch.
There are probably rear speaker wires run and dead ended at the base of the "B" pillar.
