rgatijnet1
May 21, 2020Explorer III
Your boost switch CONNECTS all batteries together so I think it would help to crank your generator. I have always believed the only way to test a group of batteries is to disconnect them from each other. If tied together for the load test, you will usually find out the condition of the worst battery. By taking them individually you can find out if only one is bad. If you have more than one battery that tests weak, it is usually advised to replace all of the batteries.
38,769 PostsLatest Activity: Jul 09, 2020
