FIRE_UP
May 08, 2015Explorer
dvleemin wrote:
Ok - so you're talking about the step inside the rv - not the kwikee step?
Both,
Our coach, an older sister of yours, an '04 Itasca Horizon 36GD with the C-7 330HP CAT, has the reservoir, pump and control panel systems, all under the entry steps, just behind the Kwikee steps. IF you lay down, in front of the coach, and look up, just behind the right front corner of the coach, you'll see the clear plexiglass cover over the control center. Behind that, which is behind the Kwikee steps, is the reservoir, manifold, solenoids and pump.
And yes, just under the lip of each of the entry steps, is a bolt or, screw. Run your fingers along the bottom lip of each of those steps and, close to the center will be the bolt. Remove that bolt, lift the step cover and, you'll expose all of what I described, only from the top view.
Now, if you feel that, that reservoir is low, make sure all the Jacks are completely up and, all the slides are completely retracted. Then, and only then, you can remove the reservoir cap and check the fluid level. Hope this helps.
Scott
38,780 PostsLatest Activity: Aug 05, 2026
