synergy7057
Nov 18, 2018Explorer
locked brakes
I have a 2002 Monaco Diplomat that I haven't driven for about 6 weeks Just went to get it ready for camping and the brakes seemed to be locked. Any thoughts?
dougrainer wrote:The low pressure warning tone/light comes on between 55 and 75 psi and it means to pull over immediately and stop before the air pressure drops low enuf to lock up the brakes. The spring brakes engage/lock up between 20 and 45 psi, the yellow parking brake knob pops out, and the spring brakes lock up the wheels. I've not read anything that says the system must have 75 psi to open the spring brakes. In actual practice, when I'm waiting for the air to come up, as soon as the alarm tone goes off at (usually) 65 psi I can immediately release the parking brake.azdryheat wrote:
Your Diplomat is a Diesel Pusher with air brakes, correct? Are you saying the brakes are still locked up with the air pressure in the normal range?
If you don't have a MINIMUM of 75 lbs on each air tank the brakes will not release. Doug
