- pump-dump-goExplorerYes, it is chevy workhorse, thanks for info on tranny, i'll check to see.
Tires are 2 years old, but rear are 5 years old, but should be good for another 2 years.
Model is M-8292 with chevy workhorse, 2 slides.
Still negotiating price - sd1209ExplorerOwned one for 5 yrs (8295 30' with 3 slides) and was thoroughly pleased with it....It had the Ford chassis..
GS has a bad rep, some deserved and some not....The coach portion of mine was good, just keep in mind it is entry level and the materials reflect that....
I put about 25K miles on it and nothing negative to report other than what might be expected...... - crassterExplorer IIThose are good coaches. Be sure to check out everything and have it inspected if you are not very mechanically skilled.... Remember, you are not just checking out a vehicle but also (somewhat) a house at the same time.
- bsinmichExplorerThat sounds like a Workhorse chassis with the 6 speed Allison Trans. It will have a grade brake that will downshift with a tap of the brake pedal for engine braking. It also has 2 overdrive positions. Great setup.
- 103hollandExplorerI have an 05 Independence with 8295 floor plan, just replaced tires with a set of Coopers at 1800 bucks. Mine is on a F53 Ford chassis with V10, 21000 miles, triple slide out.
- lj2654ExplorerWhat are the date codes on the tires?
- Johno02ExplorerWe like our 05 Gulfstream.
38,777 PostsLatest Activity: May 24, 2026
