dougrainer
Aug 08, 2013Nomad
A GAS MA from your year will not have a fiberglass roof. The Diesel MA from that year did as an option. It will have the BriteTek roof material. The Awning will be the first generation Dometic Weatherpro. They had a lot of problems those first few years and Dometic redesigned and upgraded the Weatherpro awning. I believe the ONLY corect fix for that old a Weatherpro will be a new set of arms and the new style motor. You need the Model number of the awning and need to call Dometic to verify what you need and what parts are available. Arms and motor could easily run up to $1000 for the parts. Hopefully the awning was upgraded under the original 3 year warranty. Doug
38,769 PostsLatest Activity: Mar 29, 2026
