valhalla360
Jun 28, 2022Navigator
Unless there is some sort of coupon, the last place I would consider is a dealer for an oil change.
If you have a good local shop you trust, that would be my preferred (and what we do when local for the truck).
Even most oil change shops are fine. They may need to do it in the lot if you don't fit in the bay but for an oil change, it's not rocket science and they don't need a lift.
- If you don't trust them, pay attention to what they are doing and check the plug, filter and oil level before pulling out...if those are all good it should be fine.
If it's major work, then you probably have to call around to see who can work on it.
