SJ-Chris
Jul 08, 2022Explorer II
valhalla360 wrote:SJ-Chris wrote:valhalla360 wrote:SJ-Chris wrote:
Oil change specifically is typically a SIMPLE job on Class C RVs. They are high enough off the ground that you can crawl under (or put your leveling blocks/etc underneath...of course be careful anytime you go under a vehicle!). On many Class C RVs, the oil filter is also underneath and simple to get to.
It will take you LESS time (and of course money) to change the oil yourself if you consider driving to the shop, waiting your turn (or dropping it off, getting a ride back and forth, etc), waiting for them to change the oil, and driving home.
For anything safety related, I want a certified RV shop or mechanic to perform the task (liability reasons).
Good luck!
Chris
Assuming you coordinate it with another trip (the OP was asking about while traveling so I assume there are moves involved), there is negligible drive time involved. Add in that you can typically just show up and get in within 5-10minutes and much easier than making an appointment at the dealer and paying an inflated rate. Never had to leave a vehicle at an oil change place and come back later.
Most campgrounds won't be happy with you doing an oil change at the campsite.
Here is the original post:austinjenna wrote:
Hello, we currently have a fiver but lately have been looking at smaller class c around the 25ft length. My question is having to do with oil changes and was wondering - for example if it was a Ford powered rv do you take it to the ford dealer for oil changes?
Are they generally able to work on these types of vehicles without a problem?
I don't see anything in the original post about "while traveling".
Unless my trip was for 5000+ miles, I'd either change the oil before going or when I got back.
-Chris
Quote from OP: I know I can change it myself. I was actually wondering where people go when they are out on a trip and needed to have some service done, like an oil change for example. I know if something is rv related I would need to go to an rv shop
LOL...OP posted that AFTER I posted what I posted.
38,782 PostsLatest Activity: Sep 10, 2026
