mci7
Aug 15, 2014Explorer
Agree, the cold can be an experience, I went with the Foretravel 36' with Aqua Hot, diesel fired boiler, it also has a 1500 watt electric heater element, but more, the coach has 4 adjustable thermostats, front, bath, bedroom, basement. Freezing temps down to -2 have not been an issue what so ever, I did add some insulation on the water compartment where the tank drains are located, no issues as there are vents with heater with fan to move heated air around the basement. The bottom of the coach is enclosed/covered with fiberglass, seems very tight, an certain that also helps the insulation. Oh yes, double pane windows too.
Just keep hooked up to dependable power post, if the AC fails, the generator will auto start when the batteries drop to 12.2 Volts, so an idiot proof for me, I need it.
With an earlier SOB, I also had to chase the issues, but no more.
Dave M
Dave M
