rgatijnet1
Jun 10, 2015Explorer III
If your system is thoroughly cleaned out, almost any of the name brand anti-freeze products will last close to 5 years. I would add a can of water pump lubricant to the antifreeze mix just for a little added protection. You can also use distilled water which helps a little bit, especially if your local water is high in minerals.
