saber
Jun 29, 2006Explorer
Here are a couple for you: Our 37C is in at a Workhorse facility for a left front tire that developed a leak The leak is in the wheel in the welded seam between the center hub section and the outer wheel. About 8 inches in one section and about 2 inches in the adjacent one area. Cover by warranty but----no wheels available. None in stock anywhere or at the Workhorse line. Backordered and maybe the end of August or early Sept. Workhorse and Fleetwood are working the problem and may end up pulling one off of a coach at a dealer or from the Fleetwod line. Tiffin RV in Alabama is a possible too. So, if anyone is thinking about a mounted spare, there is some lead time involved. Let you know what develops.
Secondly, in the spare time waiting for a source on the wheel, we fiddled with the instrument panel dimmer swith (wheel) and it does dim the panel light now. The dimming range is not as broad as one would suspect but it is noticeable.
38,769 PostsLatest Activity: Jun 25, 2013
