plodder
Sep 14, 2006Explorer
plodder wrote:Paul Turpin wrote:plodder wrote:Paul Turpin wrote:
Has anyone removed the ice maker? I never used the ice maker and would like to have more freezer room. I looked at it but was not too sure what I am getting into. Can the ice maker be removed without removing the refrig?
Paul
My ice maker worked itself loose and fell to the bottom of the freezer, so yes it can be removed without removing the refrig. You will need to close the valve on the water supply line. You can find that in the back of the refrig ... you'll need to remove the outside vent cover. Hope this helps.
Thanks, also can you remember what screws had to be removed? This is life, your ice maker just fell off and you had to have it replaced. Knowing my luck, my ice maker will fight me to the last screw before I can remove it.
Thanks
I will take a look at mine and get back to you on what screws to remove. If I recall there are only a couple, but I will check to make sure.
After looking at my ice maker tonight, there are three machine screws underneath going through a bracket into the ice maker. Removing the three machine screws will allow you to remove the ice maker ... when you pull it out there will be a wiring harness to unplug as well. Unfortunately the bracket will remain. I have not removed it, but there are ony another 2 or 3 screws holding it in.
Good luck.
38,769 PostsLatest Activity: Jun 25, 2013
