Paul_Turpin
Sep 26, 2006Explorer
Cathy Johansen wrote:
Leveling Jacks
I own a 2004 Pace Arrow, 37C. My question is why does my coach seem to drop slightly when I turn the ignition key off? I turn the key just enough to operate the slides or open the driver’s window. Each time the coach drops a little. Something wrong, or is this normal?
Mel
Mel
Short answer,Yes. The long answer, get your printer ready. Go to www.powergearus.com at the home page put pointer on Literature at top of page and you will get a list above it. Hit tipsheet and when it goes to that page, look at the left side of page and hit Leveling. You then get several listings, hit Power gear. You will go the the tip page with just about any question and/or advice you need for your power gear. The one for ignition dropping is tip#207. Have your printer ready, it gives info and pictures on the fix. You can do it yourself or take the printed fix to your repair shop.
Hope this helps and good luck.
Paul
38,769 PostsLatest Activity: Dec 31, 2014
