MrMudstud
Sep 27, 2006Explorer
Fyr guy wrote:I worked on mine last month, and to take it out 1st there is a frame that needs to removed and I believe it is held by 4 screws. 2nd there is a bracket on top and bottom in front of the TV held by 2 screws each.
How does one remove the front TV from the overhead cabinets?
Then just slide out the TV. You will need someone else to help you when you slide it out, one holds the TV while the other disconnects all the wires behind the TV. Then take the TV and throw it on the floor, no just kidding. You are good to go.
My small 12 V fans were in front of the sun visor and I moved them under the TV frame in the middle of the coach. Now I can run the fans and have the sun visor down. Before if I put the visor down, it blocked the fan and was not doing any good. It worked for me.........
38,769 PostsLatest Activity: Dec 31, 2014
