dcbrewer
Oct 30, 2006Explorer
On our 06 Pace Arrow, used antifreeze last year, going to use air to blow lines out this year. this is the way I done 5th wheel and TT without a problem. You still need to pull all plugs and let all run out that will and drain water heater and leave plug out, pressurize system so line going to hot water heater will empty into heater and drain out than close by-pass valve, with air on go to ever spigot starting at closet and open one at a time until only air comes out. Make sure you take ice maker lines loose to drain lines and valve behind frig. To be on safe side, I take icemaker Home. Won't do any of this next year, will be in heated garage.
38,769 PostsLatest Activity: Dec 31, 2014
