Paul_Turpin
Nov 27, 2006Explorer
I remembered reading some posts here about low water pressure/flow in their PA. I got a Watts 263A water pressure regulator with gauge from www.rvwaterfilterstore.com for $55. I am on the road in San Diego and installed it (it comes ready to mount with hose connectors).
There was not a "WOW Factor" with the water flow but it did help a lot. I can use two inside faucets at the same time with good water flow with both. The kitchen faucet if turned on all the way will splash up and out on the counter top. Shower is much better. I set it at 50 lbs and per info will deliever 4 - 5 GPM.
The big test will be in a few days when I go to a RV Park with well water and low water pressure.
38,769 PostsLatest Activity: Dec 31, 2014
