rany
Dec 03, 2006Explorer
Thanks Guys,
All valves and levers are in the correct position.
Regarding water filter on pump:I don't think the street water flow goes thru the water pump in normal use does it?
I have noticed that when filling the water tank with the bypass valve, the water pump will run full speed if turned on. Seems wierd?
I get pretty good pressure through the coach with the pump. It is just the street water that is the issue. If I am hooked up to about 90 lb of street pressure, everything is great.
The guy at the dealership who checked me out on the new orentation warned me not to use an external regulator as there was a built in one and adding an external would cause too much loss of flow. He said other people with new pace arrows had found out the hard way.
38,769 PostsLatest Activity: Dec 31, 2014
