Meme_Ray
Dec 13, 2006Explorer
seatec wrote:
Quick question. I am sure i can find it but at what location in my 06 37C can i find the water pump. im going to install a valve kit for winterizing. Anybody know right of the bat what to do about the washing machine and ice maker? Do they have specific instructions. I guess i can RTFM but you might have some tips that the manual doesnt give.
Thank you
Anthony
We let the icemaker run through a few cycles while you have a bottle of antifreeze hooked up to the pump. I think it takes several hours for each cycle and it usually takes 3 cycles. Once it makes pink ice or slush you are finished. We also run the washing machine through a shortened rinse cycle (with no drying) until we can see pink water in the washer drum. Shining a flashlight through the door glass while you are running the cycle helps to see the pink. As soon as you see pink you can shut the cycle off and then force it to spin out. It is a good idea to have one person operating the washer and one person outside watching the bottle of antifreeze. You can use up a whole bottle in the wink of an eye if you are not careful so be sure to start this process with a full bottle. After the spin cycle is over we leave the washer door open for several hours until it is dry.
Hope this helps.
Meme
38,769 PostsLatest Activity: Dec 31, 2014
