Fyr_guy
Jan 05, 2007Explorer
The only minor modifications I made to the box was....
1. Stapled the edge of the vinyl padding that was wrapped around the front edge as I needed room INSIDE the box.
2. Cut the vinyl padding at the front, inside the box
3. Remove the padding on the inside the box edge and remove a whole bunch of staples.
It was a tight fit but with the rear cross brace I know the LCD ain't going anywhere. As to the new Kigdome.. The only NEW stuff on there should just be hardware like additional LNB's (total of 5 to match the new AT9 dish Directv has for new programming) the only thing coming into the coach would be coax from the new dome into the HD receiver. Paul is right in that the wiring has to be well thought out as you should be using the best connection (HDMI) possible in order to enjoy the best picture and sound. I found spending some time on the internet at "thehdguru.com" to be beneficial as it helps walk you through a variety of set-ups.
38,769 PostsLatest Activity: Dec 31, 2014
