Meme_Ray
Jan 20, 2007Explorer
runaground wrote:
Both dash fans just quit. Checked fuse under dash. Tested switches. Fans good. Wire from dash switch to fans test good. No power to switch any one know of an inline or secondary fuse to the dash fans other than the one in the driverside box in the engine compartment?
We had this problem last year with our fans but we also had a few of the lights go out as well. After trying to solve the problem ourselves unsuccessfully we went back to the dealer. Their service shop found a loose screw that was considered construction debris in the ceiling that was bouncing around now and then and caused us electrical shorts. The dealer convinced Fleetwood to cover the repair under warranty since it was caused by construction debris. Can't say this was really the cause but the lights and fans have worked ever since. Maybe you are having a similar problem if nothing else is making sense.
Meme
38,769 PostsLatest Activity: Dec 31, 2014
