runaground
Jan 20, 2007Explorer
Thanks for the responses. Solved the problem.
The 15 amp fuse in the engine compartment marked dash fans does nothing, Nada, Zip, there is no power to it. I pulled the fuse with the fans running no affect, checked with meter no power to fuse.
What I did find is the dash fan fuse is in the bathroom under the sink 15amp General Purpose S/O fuse (Good Man R2Dillion).
Fuses under the dash seem to be as marked (in WH owners manual).
Problem was a fan, bad internal wiring. Replaced the fan replaced the fuse.
It's all good :B.
Off to Quartzsite to look at stuff, then headed South to Cancun.
Thank you all, what a great group
Larry
It's all good :B.
Larry
38,769 PostsLatest Activity: Dec 31, 2014
