dkingdoe
Jan 24, 2007Explorer
Paul,
On your 37C the fuse box may be located somewhere else. I was looking at a picture of the 37C vs. 36B and if you'll notice your main door is located where our window is and vice-versa. Our propane tank is located just under the window. And, yes there are a whole lot of fuses in that box. It's marked "Battery Control Center" (Fuses Inside). Hope this helps.
Paul Turpin wrote:
I am going to do some work on the P/A tomorrow and going to look for the fuse box you are talking about. I have to look again but I don't remember seeing a fuse box by the propane tank. What does the box look like and is there any other fuses in that box?
Pauldkingdoe wrote:
Here's an FYI ... if you've had this problem you probably already know the solution but if not thought I'd share for future reference.
Well, it was a fuse. But the strange part is that I would never have found it because ... here's the FYI ... the fuse that controls the monitor panel lights also controls the CO2 & LP gas detectors ... go figure!! It's just a 3amp fuse that's labeled LP gas. The fuse box that contains this fuse is located in the outside bin located above the propane tank.
Just sharing my info, and thanks to all who share ... Happy Camping!!!
38,769 PostsLatest Activity: Dec 31, 2014
