bricot
Jun 20, 2007Explorer
Make sure you get the correct antenna as well! The prior owner installed a CB and it didn't work well, range wasn't good, came to find out he used a grounded antenna (one design to me mounted to a METAL vehicle), I replaced with a non-grounded type and it works much better.
Paul Turpin wrote:tuff lyf wrote:
Paul Turpin... Maybe you or someone with the same make and model as me can tell me... Are there any cb hookups that come standard under the dash... Thanks
Not on the P/A I have. I didn't want to drill a hole in my rig so I got an antenna that sticks on the window and I ran the wire to under the dash. Again with the dual pane glass, I had to put the antenna on the little window on top of the driver door because the window antenna will not work thru dual pane windows. I don't use the CB very much only when there is a traffic backup to find out what lane to be in. I have found the window antenna does not have a long range.
38,769 PostsLatest Activity: Mar 31, 2026
