Paul_Turpin
Jul 10, 2007Explorer
jandn73 wrote:
My '04 Pace Arrow 37C runs electrically on shore power but I get no power from my generator. The circuit breakers on the genset are not tripped. This situation has occurred intermittently for the past three days.
I'm thinking my automatic transfer switch is not functioning properly. I will check it tomorrow for power from the genset into the switch and then see if I have power coming out of it. Is there anything that can be done to a malfunctioning switch to repair it or is it replace only?
Anyone know where it is located on my coach?
Thanks!
Jim
Asheville, NC
Jim, did you get it fixed? You should also check the power line coming into the Load Center that should be under the bathroom sink. Open up the 110 side and you should see the 10-2 Romex coming in from the power cord and the 10-2 Romex generator power cord. If they are not marked inside the box, remove the four corner screws and the complete box can be pulled partway out of the sink cabinet and check the 110 wires going into the box for markings. Check to see if you are getting power from the generator also check to see if you are getting a good connection on your generator wires. I had a bad connection on a 110 wire that had to occur after 2 years of driving down the road. Good luck and let us know how it worked out.
38,776 PostsLatest Activity: May 14, 2026
